New Product: Rotary-lobe blower
Weighing in at 1.75 lb and measuring 6-in. long, the RL Series rotary-lobe blower’s small size is possible through an assembly process that minimizes leak paths within the blower chamber.
May 8, 2008
The unit, which features a 12-V brushless dc motor and permanently lubricated timing gears, delivers 1.900-cfm air flow, 2-psi pressure, and 4-in.-Hg vacuum. The blower comes with a 3/8-in. OD hose barbs and 6-in. wiring harness and can be mounted vertically or horizontally.
Thomas Products Div., a Gardner Denver Co., 1419 Illinois Ave., Sheboygan, WI 53081, (920) 457-4891, www.gardnerdenver.com
