High-Density PLC Relay Interface
Feb. 22, 2007
The CWRE Series of 6.2-mm-wide PLC relays consists of base terminal blocks and pluggable relays.
The heavy-duty electromechanical relays are rated for ac or dc circuits and can be replaced quickly without having to remove the wiring. There are four models: 24 Vdc, 24 Vac/dc, 120 Vac/dc, and 230 Vac. The CWRE Series easily mounts on a DIN rail and features LEDs and a pluggable jumper, which can be used to easily common the coil and contact connections, eliminating up to 60% of the wiring normally associated with industrial relays.
Automation Systems Interconnect Inc.,
Box 1230, Carlisle, PA 17013,
(717) 249-5581,
asi-ez.com
Aug. 15, 2025
Aug. 15, 2025
Aug. 15, 2025
