Bearings Products: Clutch Release Bearings
Tool steel comprises the contact face, and the bearing unit itself is sealed to eliminate runout.
The 40-060 and 40-070 models fit clutches with 7, 8, 10, and 11-in. diameters. The 40-010 and 40-020 models are for 6.25-in. clutches. Replacement bearings are also available. All models have antirotational collars and are designed not to deposit grease on the clutch assembly.
RAM Automotive Co.
201 Business Park Blvd.
Columbia, SC 29203
(803) 788-6034
ramclutches.com
