Electro-Pneumatic Pressure Regulator
Sept. 28, 2006
The ED02 pressure regulator is a compact device measuring 76 X 60 X 30 mm. It has a directly-controlled 2/2-way proportional valve that allows an air flow of 3.5 Scfm (100 1/min).
Four ED02 series pressure regulators can be linked to each other without a base plate. Voltage supply, analog set point, and actual value are electrically connected via a central M12 plug. It is available with the IP65 (NEMA 4) protection, comes with a microprocessor that controls exact regulation, and provides repetitive precision of 0.44 psi (30 mbar) and values with a hysteresis of 0.73 psi (50 mbar).
Bosch Rexroth, 5150 Prairie Stone Parkway, Hoffman Estates, IL 60192, www.boschrexroth-us.com
Get better products to market faster. This e-book reveals how industry leaders are adopting an agile approach to product development with integrated design and collaboration software...
Aug. 7, 2025
Change is difficult, but with the right plan, it can be successful. Learn from Rathbane Group's transition from 2D to 3D and their strategies for leveraging efficiencies and mediating...
Aug. 7, 2025
Discover how the Autodesk Platform helps you embrace a cloud-first evolution in design and manufacturing, connecting your data and unleashing your agility with AI-powered insights...
Aug. 7, 2025
Explore the future of digital transformation with AI. Discover how companies are harnessing its power to automate processes, increase productivity, and navigate the ethics of ...
