Pump Bearing
A double-row design and 40° stepper contact angle lets the 3300 DNR Series pump bearing meet the higher thrust demands of ANSI-style pumps.
The unit's machined brass cage improves performance in heavy-duty and poorly lubricated conditions. Axial and internal clearance ranges permit load sharing between the two rows of balls for cooler operation, reduce lubricant degradation, and minimize destructive skidding in the inactive row. A range of seals, shields, and snap-ring options are available.
SKF USA Inc., 1510 Gehman Rd., Kulpsville, PA 19443, (800) 440-4753, skfusa.com
