High-Power Induction Servomotor
High-Power Kinetix (HPK Series) motors use an optimized winding design that mimics the speed/torque curve of conventional PM servomotors to deliver peak torque that is twice the continuous torque running at base speeds.
May 10, 2007
The motor also comes with single or multiturn, high-resolution absolute feedback that eliminates homing routines, improves velocity regulation, and expands inertia matching capacity. The motor is fully optimized when combined with the Kinetix 7000 high-power servodrive, extending the power range of traditional servomotors up to 150 hp.
Rockwell Automation Response Center,
10701 Hampshire Ave. S, Bloomington, MN 55438,
(800) 223-5354,
ab.com
