Connectivity And Sensing
Brochure covers automation connectivity and sensing products including cordsets and extension cords, M8 and M12 connectors, distribution boxes, industrial automation sensors, and solenoid-valve connectors and cables.
Oct. 12, 2006
Highlighted are male and female connectors available in either 90° angles or straight with molded cables, PVC, shielded, PUR, and special requirements with or without LED indication. Solenoid-valve connectors used in hydraulic, pneumatic, and electrical applications for pressure switches, filter switches, limit switches, and special sensors are also covered.
Automation Systems Interconnect Inc., Box 1230, Carlisle, PA 17013, (877) 650-5160
