Piston Pumps
Series 1207 WOB-L piston pumps are designed for pressure and vacuum needs in a variety of industrial, medical, and commercial applications.
May 5, 2005
Applications include packaging equipment, plasma welders, business machines, pneumatic tools, and respirators. They are designed with oilless, nonlube piston and cylinder for long life and clean airflow. Bearings are permanently lubricated. Other features include stainless-steel valves, hardcoated aluminum cylinder, and high-performance piston seals of a PTFE compound. The pumps are powered by capacitor-start motors of air-over design that allow for maximum cooling of the motor and cylinder head. Series 1207 pumps deliver flow up to 4.3 cfm (121.5 lpm), pressure to 125 psi (8.6 bar), and vacuum to 28-in.-Hg (949 mbar).
Rietschle Thomas Sheboygan
1419 Illinois Ave.
Sheboygan, WI 53082
(920) 457-4891
www.rtpumps.com
