High-Pressure Pump
April 26, 2007
The ZA4 hydraulic air-driven pump features high oil flow and bypass pressure, and is safe for use in refineries, petrochemical, and oil and gas-processing plants.
It reportedly has an industry-leading 10-kpsi hydraulic flow rate that should boost productivity. Reservoirs come in 1 to 10-gallon capacities. A sight gage on the 1 and 2-gallon models and a level gage on the 2.5, 5, and 10-gallon reservoirs allow quick and easy level monitoring.
Enerpac BV,
Box 3241, 6100 N. Baker Rd., Milwaukee, WI 53209,
(262) 781-6600
enerpac.com
Clean. Compact. Less heat.
April 16, 2025
