Product Spotlight: Miniature Ball Valves
The stainless-steel shut-off version weighs 9 gm and the two stainless-steel diverting models weigh 12 gm. The mixing diverting valve lets users select either or both ports with no shut-off. All models use 316 stainless-steel ball elements and are available with Buna-N, EPDM, or Viton seals. Inlet and outlet ports are 10-32 UNF standard.
Beswick Engineering Co. Inc.
284 Ocean Rd.
Greenland, NH 03840
(800) 354-5014
beswick.com
