Parallel-shaft gearmotors
PS1900 parallel-shaft gearmotors are available in 14 gear ratios from 5:1 to 320:1.
Gearmotors feature rugged powdercoated cast-aluminum housings, standard face and foot mounts, and continuous-duty torque to 125 lb-in. They are compatible with all Groschopp ac, pm, and dc brushless motors. The use of synthetic lubricants improve heat dissipation while internal ball bearings and needle bearings on output shafts boost overhung load capacity and provide quiet operation.
Groschopp Inc.,
420 15th St. NE, Sioux Center, IA 51250.
(712) 722-4135.
www.groschopp.com
