Circuit Tray Clip
Antistatic integrated circuit tray clips eliminate the need for operators to manual mark (drawing lines, writing dates or instructions, and pasting papers) Jedec trays.
Suitable for use and reuse of IC trays, the color-coded clips are durable and can be used to identify single or stacked trays. The devices are compatible with rebaking processes used with moisture sensitive devices and withstand temperatures to 300°F. The clips are manufactured of high-strength PBT and polyether.
Keystone Electronics Corp. 31-07 20th Rd., Astoria, NY 11105, (718) 956-8900, keyelco.com
