Shafts and pulleys are easily accessible, eliminating disassembly of machinery parts. The lock can also be easily disconnected. The belt's finger-spliced ends are ready for clamping using the kit's hardware, which consists of carbon-fiber-reinforced polyamide connecting plates and tooth inserts including the screws (two/plate). Belt width determines tensile strength: 32 mm is 550 N, 50 mm is 750 N, 75 mm is 1,000 N, and 100 mm is 1,500 N.
BRECOflex Co. L.L.C., 222 Industrial Way West, Eatontown, NJ 07724, (732) 460-9500, brecoflex.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
