3-Φ Power Distribution Center
The 3- power distribution center contains 30 "three-prong" (NEMA-5-15R) or "T-blade" (NEMA-5-20R) receptacles to power a maximum of 48-A continuous current at 120 V.
The VPC2864 stands 68-in. tall (70 in. with standard brackets installed) and only 2-in. deep. The units require no rack space being mounted either on the back or side of an enclosure. A two-digit current meter is switch selectable between phases so installers may properly balance phase currents and monitor against overloading. Power input is via a 3 NEMA-L21-20P power connector (120/208 V at 20 A) on a 9-ft power cord.
Pulizzi Engineering Inc., 3200 S. Susan St., Santa Ana, CA 92704, (714) 540-4229, pulizzi.com
