New Product: Right-angle gearmotor
A light-duty, self-contained worm-gear drive includes a dc motor, gearbox, output shaft, and brake.
Nov. 8, 2007
The Model MC137C has a hardened-steel and bronze gear assembly with lifetime lubricated ball bearing enclosed in a high-strength, heat-treated, and corrosion-resistant aluminum housing. Gearbox ratios range from 8.5:1 to 63:1 with custom output shafts available up to 0.875-in. OD. Mounting flanges accommodate three or four bolts positioned on a 2-in. center. The unit comes with a 0.25 or 0.44-hp TENV permanentmagnet dc motor. Operating voltages available include 12, 24, 36, 90, or 180 V. Other motor options may be available on request.
Euclid Universal, 30500 Bruce Industrial Pkwy., Suite B, Solon, OH 44139, (440) 349-4083, eucliduniversal.com
