Circular Signal Connectors
The panel-mounted, dual-function M23 connector is suitable for screw and push-pull (quick-disconnect) connection.
The threaded male panel-mounted connector has locking grooves. Initial connection can be done with the female screw connector and later be converted to the push-pull concept without replacing the male connector. Available connectors include a single with six to 19 pins carrying 8 to 20 A and a power connector with six to eight pins carrying 8 to 28 A.
Sealcon,
14853 E. Hinsdale Ave., Suite D, Centennial, CO 80112,
(303) 699-1135, www.sealconusa.com
