Fluid Connectors
All engineered connectors are made to customer specifications.
Onepiece construction requires no brazing when incorporated into the fluid system. Bar-stock construction allows for a full wrench pad, required for installation in tight spaces. These components are designed for use with hydraulic fluid, oil, air, refrigerants, water, fuels, and greases. Fluid Line Products, Box 1000, Willoughby, OH 44096, (440) 946-9470, fluidline.com
