It features a bottom port O-ring connection for direct vacuum connection to endofarm tooling, eliminating the need for inefficient pipe connections. The 25-mm low-profile unit weighs only 80 gm, and standard features include a push-to-connect pressure port, four-bolt mounting pattern, and internal filter screen. The reliable, single-stage design has no moving parts. Options include a top vacuum/gage NPT port connection. High, mid, and low-vacuum models are available.
Pneumatic Vacuum Innovations, 407 W. Imperial Highway, Suite 317H, Brea, CA 92821, (714) 392-4784, pneumatic-vacuum.com
