The 10 and 15-mm direct-acting solenoid-valves come in two or three-way configurations as normally open or normally closed.
The 10 and 15-mm direct-acting solenoid-valves come in two or three-way configurations as normally open or normally closed. Available flow rates are 0.5 to 3.0 scfm depending on the orifice size. Features include a highly visible LED indicator and manual override, quick response time, and multiple mounting and voltage options.
