Plug-In Valves
New VTSA Series is a modular plug-in valve system that simplifies adding and removing subbases and valves.
Nov. 17, 2005
It conforms to new ISO Standard 15407-2, which defines the valve interface for 18 and 26-mm valves with plug-in electrical connections. A wide range of pneumatic functions gives flexibility to users. Electrical interfaces include terminal box, multipin connection, and CPX fieldbus, all with the capability to drive 32 solenoids. Subbases have G or NPT ports and a single subbase for mounting an individual valve is also available. The robust IP65/NEMA-4 manifold system ensures reliable operation in most industrial environments. It is suited for a wide range of installations, from 110 Vac and terminal box to those with fieldbus communications, in automotive, packaging, printing, pharmaceutical, and other applications.
Festo Corp., 395 Moreland Rd., Hauppauge, NY 11788, (631) 435-0800, festo.com/us
