New Product: HDS Heavy Duty Slide System Gets the Job Done
March 20, 2008
The HepcoMotion® HDS is a versatile, easy to install, low maintenance, affordable high load slide system.
HDS is primarily designed for applications requiring high load capacity (axial loads 2,500N – 20,000N) and system rigidity. It’s available in a wide range of complementary and interchangeable components allowing unlimited design options. Slideways are available in both precision ground and commercial grades. HDS is excellent for harsh environments.
Bishop Wisecarver
888.580.8272
www.bwc.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
