New Products: Cable-Extension
The SR1A-125 cable-extension transducers are designed for use in wet and outdoor applications. Each offthe- shelf unit comes complete with a versatile mounting bracket that provides multiple cable-exit direction options for vertical or horizontal use
Nov. 22, 2008
The SR1A-125 cable-extension transducers are designed for use in wet and outdoor applications. Each offthe- shelf unit comes complete with a versatile mounting bracket that provides multiple cable-exit direction options for vertical or horizontal use.
The transducer has a 500-OHM pot (having voltage divider output) and a 125-in. measurement range. An M12 connector comes with the transducer as well as fully retractable stainless-steel measuring cable. The cable wraps around the internal spring-loaded spool coupled to a precision sensor. The movement of the spool produces a voltage directly proportional to the position of the measuring cable.
Celesco Transducer Products Inc.
20630 Plummer St.
Chatsworth, CA 91311
(800) 423-5483
celesco.com
