Shuttle valve - The Lee Co.
The 5.5 × 12.2-mm IMH shuttle valve has a nondetented, selective design to solve problems with hydraulic isolation in manifolds. This new valve is suitable as a signal for auxiliary functions, such as hydraulically released, spring-applied brakes and load-sensing applications. The stainless-steel shuttle valve easily installs into a drilled hole, eliminating the need for threads, O-rings or in-house designs.The Lee Co., 2 Pettipaug Rd., Box 424, Westbrook, CT 06498, (860) 399-6281, theleeco.com
