The TDL2 and TDL4 two-post direct lifters have linear bearings for smooth, consistent lifting action. The lifters feature HP Series metric air cylinders with adjustable cushion control, built-in lubrication system, and position-sensing capability.
The TDL2 comes in ø40 to ø100-mm bore sizes and 25 to 40-mm stroke lengths. The TDL4 is equipped with a ø40-mm-bore air cylinder in 25 to 250-mm stroke lengths.
Dadco
43850 Plymouth Oaks Blvd
Plymouth, MI 48170
(800) 323-2687
dadco.net
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
