Product Spotlight: Stainless-Steel Gearmotors
The KESA37 stainless-steel gearmotor provides motion anywhere machines and systems must be cleaned intensively.
The KESA37 stainless-steel gearmotor provides motion anywhere machines and systems must be cleaned intensively. The unit’s special stainless-steel housing makes it suitable for use in the food, beverage, and pharmaceutical industries, as well as in constantly wet environments.
The gearmotor’s easy-to-clean surfaces have a high-grade resistance to acid and alkaline. Most recesses that collect dirt and liquid have been eliminated. All seals and connections are available with IP69K protection. The gearmotor features 200-Nm maximum output torque and a 3.98 to 106.38 gear ratio.
SEW-Eurodrive Inc.
1295 Old Spartanburg Highway, Box 518
Lyman, SC 29365
(864) 439-7537,
www.seweurodrive.com
