Battery isolators eliminate battery drain in vehicles and equipment with multiple batteries. The isolators prevent accessories from draining the starting battery and allow two batteries to be charged simultaneously. The isolators feature embedded electronic components for protection from contamination and vibration; an integral heat sink for efficient heat dissipation, and are rated for 12 to 36-Vdc negative ground systems.
Waytek Inc.
2440 Galpin Court, Box 690
Chanhassen, MN 55317
(800) 328-2724
www.waytekwire.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
