New Products: Flange-Mount Safety Screens with High Burst Pressure
High Pressure 17-7PH Flange Mount Safety Screens are said to provide high burst and collapse pressures averaging more than two times those of existing 304L designs
The High Pressure 17-7PH Flange Mount Safety Screens are said to provide high burst and collapse pressures averaging more than two times those of existing 304L designs.
Available in seven different flange sizes ranging from 0.130 to 0.656 in. in diameter, the screen’s standard hole sizes range from 0.004 to 0.015 in. The screens are completely interchangeable with existing etched, flange-mount products and use the same configuration to provide maximum open screen area for increased dirt holding capacity.
The Lee Co. 2 Pettipaug Rd. Box 424 Westbrook, CT 06498 (800) 533-7584 www.theleeco.com
