Save time with IEC 61131-3
Mechatronic control system works with IEC 61131-3
MotionWorks IEC Mechatronic Control System features software that is fully compatible with the global programming standards specified by IEC 61131-3 and PLCopen. The system also includes the MP2300Siec controller, offering EtherNet/IP, Modbus TCP/IP, and Mechatrolink network connectivity for up to 16 axes of motion control. MotionWorks software incorporates PLCopen function blocks for motion control — standard code libraries that store previously written logic, significantly reducing development time. An integrated Web server accelerates troubleshooting. The 2.5-in. wide controller implements the Mechatrolink high-speed digital network for tightly integrated motion and I/O, even when complex motion such as camming or gearing functions are required. Visit www.yaskawa.com or call (800) YASKAWA.
Dual-port Ethernet controller simplifies connectivity
Designed for networking convenience and versatility, the 750-871 Ethernet TCP/IP 2-port programmable fieldbus controller links the WAGO-I/O system to the Ethernet fieldbus. Two RJ-45 fieldbus connection ports provide daisychaining capability for up to 20 devices (as far as 100 m) within one series. The controller is programmable in accordance with IEC 61131-3 and features an integrated dipswitch for IP address assignment. A battery-backed, real-time clock and 32-bit multitasking CPU allow the controller to reliably support a variety of applications. For additional timesaving and convenience, HTML pages can be placed on the internal server for use in Web-based applications. Visit www.wago.us or call (800) DIN-RAIL.
Speedy PLC reduces engineering time
The IndraControl L10 PLC features scalable hardware, pre-developed machine functions, reusable code, and unified programming software to reduce engineering time for machine builders who work with complex equipment. Suitable for general automation, converting, packaging, machine tool, and other industries, the L10 offers a full megabyte of program storage space and an Ethernet port for remote access or SCADA functionality. To save engineering time, the L10 comes with dozens of PLCopen machine functions pre-programmed according to IEC 61131-3 standards. The L10 offers expandability up to 256 I/O. Visit www.boschrexroth-us.com.
Servo drive teams up with IEC 61131-3 programming
The SMLC-SA combines high-performance drive technology with the IEC 61131-3 programming capabilities of the SMLC controller. Standard PLCopen motion control function blocks reduce software development time, and application-specific function blocks such as “reciprocating flying shear” and “rotary knife” are available as out-of-the-box solutions. The SA230 series offers eight models with continuous output current from 2.5 to 60 A RMS/phase for 115 to 230 Vac input. The SA460 series offers six models with continuous output current from 5 to 50 A RMS/phase for 230 to 460 Vac input. The SMLC-SA provides scalability from one to 16 axes and users can program logic and motion using all five IEC 61131-3 languages. Visit www.ormec.com or call (585) 385-3520.
