Pneumatic solutions
Modular air preparation system Easy-to-assemble FRLs come with mounting brackets and embedded square outlet pressure gauges. Features & benefits Port
Features & benefits
  • Port sizes from ⅛ to 1 NPT; four sizes have die-cast aluminum and black anodized bodies for corrosion resistance
  • Polycarbonate bowls with guards attach with quick-mount bayonet system
  • Push-to-lock adjustment knobs on regulators maintain precise pressure settings under extreme vibration
  • Low pressure drop across lubricators assures lubrication rate proportional to air flow
Fabco-Air Inc.
Gainesville, Fla.
(352) 373-3578
www.fabco-air.com
Circle 243
Air cylinders
Family of air cylinders comes in compact, ISO, pen-size, and stainless-steel miniature designs.
Features & benefits
  • Compact models have bores from 12 to 100 mm; strokes from 50 to 130 mm
  • ISO 6431 models have bores from 32 to 200 mm; strokes from 25 to 100 mm
  • Pen-size models have bores from 4 to 16 mm; strokes from 5to 300 mm
  • Stainless-steel models have bores from 16 to 63 mm; strokes from 25 to 500 mm
MFD Pneumatics
Chicago, Ill.
(866) 264-9560
www.mfdpneumatics.com
Circle 244
