Pneumatic solutions
Rodless band cylinder
Ultran Band rodless cylinder seals mechanical piston/yoke connections.
Features & benefits
18 to 63 mm bore sizes (inch available)
Stroke length to 3 m
Sealing efficiency rating of 100 sccm leakage
Cushioning and position-sensing capabilities; optional side-guiding attachment increases load capacity
Bimba Manufacturing
Monee, Ill.
(708) 534-8544
www.bimba.com
Circle 134
Air cylinders
Pancake II interchangeable pneumatic cylinders offer high load bearing capacity, reduced friction, and zero slip stick.
Features & benefits
Four styles and eight bore sizes from ½ to 4 in.
High strength, self-lubricating composite cylinder barrels and oversized, non-metallic piston rod bearings
Standard, non-rotating, force-multiplying, and 3-position models
Fabco-Air Inc.
Gainesville, Fla.
(352) 373-3578
www.fabco-air.com
Circle 135
