Scanning For Ideas: Profibus Connector Designed With Field Installation in Mind
There are only two parts: a housing and a contact carrier with locknuts. The connectors are fully shielded and provide IP67 and NEMA-6P protection (when fully locked). Nominal voltage is 60 V; nominal amperage is 4 A. Contacts are precopper-plated brass. They operate in temperatures from 13 to 104°F.
Related
Supplier Submitted
