AI-Powered Process Tracing: Cutting Costs, Improving Compliance
In precision manufacturing applications, such as aerospace and defense, insufficient process tracing poses a risk of proof-of-conformance issues, in which a manufacturer can’t sufficiently demonstrate that a specific part was made from the approved material, produced under a controlled process or properly inspected and calibrated. A traceability failure does not prove that a component was defective or that anything is wrong with production but it can make it impossible to establish its eligibility for use.
When a process genealogy is incomplete, containment scope can grow dramatically if the affected material, supplier lot, machine setup or inspection record cannot be connected to individual serial numbers. When that occurs, manufacturers have to suspect a broad production population rather than a small grouping, creating avoidable costs for reinspection, teardown, validation or logistics.
The reputational risk is significant and failure to maintain an acceptable system may lead to purchasing-system disapproval or withholding of payments, in addition to the direct costs incurred.
Being able to reconstruct the as-built history for a particular serialized unit or lot is critical to meet the strict process-tracing standards implemented in many precision manufacturing applications. Robust process tracing can include material sources, process parameters, inspection results and process genealogy evidence linking identity specifically to the process steps. Effective tracing lets an organization say, “These exact serial numbers, from this lot, processed on this equipment under this revision require action.”
Decades ago, the primary record for process tracing was contained entirely in paper documents that accompanied a work order or an individual part through the process. Frequently, these records contained missing information or errors. The digitization of records didn’t fully solve the problems of paper recording. Siloed data and processes frequently required operators to merge or manually copy digital data into spreadsheets, trading one set of paper errors for a new set of digital ones, leading to mistakes and creating additional process overhead and inefficiency.
Modern industrial connectivity approaches to machine and process design enable standardized, secure communication among machines, control systems, MES and ERP systems, providing platform-independent, reliable connectivity that facilitates advanced unit-level process tracing as part of machine design, and eliminates manual data-merging steps for processes occurring within connected machines.
Many complex products have final assembly steps that occur outside connected machines. For example, if data and power cables are seated by hand as part of final assembly, can these manual process steps benefit from digitized process tracing and avoid creating a documentation risk?
Process Tracing AI: The Missing Link
Machine vision has been a familiar tool for manufacturers for many years. Whether for process monitoring, dimensional measurement or QA applications, machine vision has traditionally operated as part of a rule-based vision system.
It is well known that when applying machine vision to machine or process designs, calibrating these systems can be complex and rule-based vision programming is highly sensitive to unexpected variations. Because of this, although traditional machine vision is highly effective in specific applications without unexpected variations, it cannot be widely applied to every use case.
Trained machine learning models have rewritten this expectation over the past few years. AI vision solutions apply machine learning to machine vision to solve complex QA problems, drive robust safety systems, empower Autonomous Mobile Robots (AMRs) in warehouses, and dynamically confirm item counts and packaging in logistics operations. AI-enabled vision technology offers an opportunity for manufacturers in precision manufacturing applications to connect the final missing links for end-to-end digitalized process tracing.
AI vision models can create a complete record in a dynamic environment, attaching timestamps, still images and validation proofs to key process steps. By training a machine learning model on a specific process, machine vision can capture a part number, validate proper assembly (seating, alignment, screw torque, etc.) and confirm final measurements, with support from data from multiple sources and validation using the vision data.
The instantly recognizable advantage of AI for process tracing is eliminating the risk of human error when documenting manual process steps. Rather than asking the operator or line assembler to select or enter a serial number correctly hundreds or thousands of times, the serial number can be captured automatically. Instead of an inspector notating validation measurements, the AI process-tracing model can append data from connected digital torque wrenches or calipers directly to the record.
Removing the repetitive manual steps required for process tracing reduces risk and creates higher efficiency. Of course, there is still a risk of errors in any process. A properly trained machine learning model eliminates the risk of human error, but poor imaging, flawed model training or weak system integration can still lead to an inaccurate record.
Agile production environments—where process steps, key metrics or entire products may change frequently—create additional process-tracing risks and challenging situations. Vision delivers dynamic evidence of what happened during a process step, but traditional machine vision has been particularly prohibitive for the demands of agile production.
Programming traditional rule-based machine vision solutions for a custom product variation or new product iteration can incur substantial costs. Machine learning supports agile manufacturing and unique product variations by enabling rapid reconfiguration.
Vision-based models utilize training by “doing,” in which compliant parts or process steps are demonstrated to the model, and key examples of known non-compliance are also provided. The ability to rapidly adapt the process tracing vision system to changes in assembly steps or product configurations creates an opportunity for manufacturers that need process agility to stay competitive while also meeting strict process tracing requirements.
AI-enabled vision can close the process-tracing gap between connected production equipment and the manual assembly, validation and final-inspection steps that remain essential in precision manufacturing. By automatically linking visual proof, part identity, tool data, measurements, timestamps and process outcomes to the correct serialized unit, manufacturers can build a more complete and defensible as-built record without burdening operators with repetitive documentation tasks.
The objective is not to remove human judgment from quality assurance, but to reduce avoidable transcription and association errors while providing qualified personnel with stronger evidence for exception handling, root cause analysis, audit readiness and continuous improvement.
As products, configurations and workflows become more variable, adaptable AI vision models offer a path to preserve both production agility and the rigorous proof of conformance demanded by aerospace, defense and other precision manufacturing environments.
Matthew ThorntonMatthew Thornton
Founder and Chief Product Officer, Rapta
Matthew Thornton is a Founder and Chief Product Officer of Rapta, a Manufacturing Intelligence Platform and compliance-driven decision-support Quality-as-a-Service framework. A 23-year veteran of Siemens, Matthew is a factory automation expert, with a deep understanding of deploying Industrial IoT for manufacturers.
