Low permeation tubing
Low Permeation PFA Tubing is for applications where permeation and oxidation can cause premature failure of the tubing and foul the purity of the chemical or process media inside the tube. Tubing is available in standard sizes from , , and 1-in. ODs with 0.062- in.-thick walls. Additional sizes and samples are also available upon request.
Parker Hannifin Corp., Fluid Connectors Group Parflex/Tex- Loc Div., 4700 Lone Star Blvd., Ft. Worth, TX 76106, (800) 438-9562, texloc.com
