Linear guideway
The lightweight MGN Series linear guideway, suitable for miniature equipment, is made of a special grade of corrosion-resistant stainless steel. Sizes 9 and 12 are also available in alloy steel. The guideway’s rollingcirculation system consists of a block, rail, end cap, and retainer. Its Gothic-arch design sustains loads from all directions and offers high rigidity and accuracy. A miniature retainer holds the steel balls to prevent them from falling out when the blocks are removed from the rail installation. End and bottom seals protect the guideway from dust.
LM76 Linear Motion Bearings
140 Industrial Dr.
E. Longmeadow, MA 01028
(800) 513-3163
