In-line gearhead
The alpha LP+ Generation 3 gearhead is the same size as its predecessor but features increased power, smoother running, more ratios, and is said to offer up to 75% higher torques, resulting in a 50% reduction in operating noise.
The gearbox is suited for servo applications in packaging, handling, and automation systems. Output can be designed with a smooth or keyed shaft. The unit is also available as the LPB+ Generation 3 with output flange and in a two-stage version with increased ratios.
Wittenstein Inc.
1249 Humbracht Circle
Bartlett, IL 60103
(888) 534-1222
© 2012 Penton Media, Inc.
