Brass Water Turbines
The FTB370 water turbines are designed for flow-rate measurement of water and many water-based liquids. High-quality sapphire bearings ensure an extend life expectancy, and the uniform bearing-load design minimizes bearing wear. This turbine features a fixed pulse rate, wide turn-down ratio, and is NEMA-3 (IP54) rated.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (203) 359-1660, www.omega.com
