Compact Distribution Manifolds
The J6 Series distribution manifolds control multiple outlets from a single source inlet.
Assemblies can range from 4 to 18 needle-valve/outlet connections and valves can be individually isolated for precise control. The lightweight manifolds feature a onepiece integral body rated up to 6,000-psig working pressure. For use in gas or liquid applications, the units have fewer potential leak points than their conventional counterparts.
Swagelok Co., 29500 Solon Rd., Solon, OH 44139, (440)349-5934, www.swagelok.com
