Two-Part Adhesive
Medium-viscosity Tra-Bond 2101 is a two-part adhesive that readily bonds to clean, dry surfaces including metals, ceramics, glass, wood, leather, and rigid plastics.
Aug. 10, 2006
The adhesive resists many organic and inorganic components including mild acids and alkalis. Tra-Bond 2101 has a 30-min pot life, can be room-temperature or heat cured, and has a lap-shear strength of 3,300 psi.
Tra-Con Inc.,
45 Wiggins Ave., Bedford, MA 01730,
(800) 872-2661, tra-con.com
