Varible Displacement Pump
Sept. 15, 2005
The A14VG high-pressure pump is available in Size 90 for standard mixers and Size 110 for larger mixers.
The pump comes in 12 and 24-V models with pressure capabilities up to 450 bar. High-pressure suction and drain lines are located on the same side for limited space line routing. Actuation of pump displacement is accomplished directly via an electroproportionalpressure-reducing valve. The pump's shaft seal is designed for quick and easy changeovers. Its overall length and through-drive options, SAE-A and SAE-B, targets the unit as an auxiliary pump in vehicles.
Bosch Rexroth Corp., 1700 Old Mansfield Rd., Wooster, OH 44691, (330) 263-3434, www.boschrexroth-us.com
June 27, 2025
June 25, 2025
June 25, 2025
