Linear Guideways
The new Linear Guideways incorporate a patented recirculation system for smooth linear motion with little noise.
The new incorporate a patented recirculation system for smooth linear motion with little noise. The lube-retaining end caps and sealed bearing blocks reduce friction ensuring quiet, accurate operation. End seals with optional double seals and scrapers offer added protection from contamination. Models handle different load ranges from light to heavy-duty with various levels of precision and dust protection.
Warner Electric, 449 Gardner St., South Beloit, IL 61080, (800) 234-3369, warnerelectric.com
