Large OD Tubing
Clear, flexible PVC and polyurethane tubing is available with up to 3-in. OD.
They are for air and gas lines, fluid discharge and transfer, protective jacketing and insulation sleeving, as well as powder and granular transfer applications. The tubing comes in 47 sizes with the smallest starting at 1/16-in. ID. Polyurethane tubing is stocked in sizes ranging from 1/16 to 2-in. ID, with custom 2.5 to 2.75-in. ID available on request. Either material can be colorized, specially packaged, and cut to specified lengths. A more durable PVCpolyurethane blend that features less surface tack is also available.
NewAge Industries Inc., 145 James Way, Southampton, PA 18966, (800) 506-3924, www.newageindustries.com
