Two-Part Adhesive
Tra-Bond 2143D is a polyamide epoxy adhesive for use where impact resistance and superior mechanical properties are critical.
The two-part medium-viscosity formulation can be room-temperature or heat cured and has a Tg of 65°C. Tra-Bond 2143D has low-moisture absorbance and lapshear strength of 2,200 psi. It bonds with most metals, rigid plastics, glass, ceramics, leather, rubber, and wood.
Tra-Con Inc.
45 Wiggins Ave.
Bedford, MA 01730
(800) 872-2661
tracon.com
