Linear Pumps
Series 6000 linear pumps use few moving parts and no bearings, contributing to long service-free life.
High-flow diaphragms and intake heads made of high-density, sound-absorbing plastic limit operational noise. Both 12 and 24-Vdc models provide up to 1.5-cfm (42.5-lpm) airflow as standard. Maximum pressure is rated at 4.0-psi (0.28-bar) continuous or 4.7-psi (0.32-bar) intermittent. The maximum vacuum rating is 8-in. Hg (27 mbar).
Rietschle Thomas Sheboygan Inc.
1419 Illinois Ave.
Sheboygan, WI 53082-0029
(920) 457-4891
rtpumps.com
