Single-Axis Tilt Sensor
The Single-Axis Linear Output Electrolytic Tilt Sensor has a ±30-arc minimum angle range.
The Single-Axis Linear Output Electrolytic Tilt Sensor has a ±30-arc minimum angle range. The sensor is designed for applications needing ultrahigh accuracy, excellent null repeatability, and linear output, making it suitable for construction laser instruments and transits, aircraft avionics, geophysical monitoring, machine-tool leveling, and medical positioning or monitoring.
The Fredericks Co., 2400 Philmont Ave., Huntingdon Valley, PA 19006, (215) 947-2500, frederickscom.com
