The self-priming pumps can run dry without damage or with flow outputs of 0.40 to 5.3 gpm at pressures to 100 psi. The units handle fluid temperatures to 104°F. Uses for the pumps include agricultural spraying equipment and fluid-transfer applications.
Delavan AG Pumps Inc., 1228 Chestnut Ave., Minneapolis, MN 55403, (866) 335-2826, delavanagpumps.com
Aug. 21, 2025
