Flexible Shafts
The A 7C13M (metric) and A & C13 (inch) Series of flexible shafts for remote-control assemblies are designed to be panel mounted without a casing.
May 11, 2006
The A 7C13M (metric) and A & C13 (inch) Series of flexible shafts for remote-control assemblies are designed to be panel mounted without a casing. The units range from 3.3 to 4.8 mm in diameter and 76 to 355 mm in length. The shafts operate in manual mode and have a curvature radius from 38 to 500 mm.
Stock Drive Products, 2101 Jericho Turnpike, Box 5416, New Hyde Park, NY 11042, (516) 328-3300, sdp-si.com
