New Products: Misalignment Coupling
The Step-Beam misalignment coupling are plastic molded devices that replace stainless-steel and aluminum metal-beam or bellows counterparts while providing the same or higher torque ratings, as well as voltage and RF isolation.
The units feature positive metal to metal shaft clamping, light weight, –20 to 140°C operation, and can directly replace many , , and 1-in.-diameter metal beam couplings.
Rino Mechanical Components Inc.
215 N Main St.
Freeport NY 11520
(888) 260-7466
rinomechanical.com
