Pint-Sized Servomotor
The MM Motor is a small industrial servomotor that provides unlimited linear or rotary motion with 0.17 N of driving force and velocity up to 250 mm/sec.
The 9 X 17 X 5-mm motor weighs 5 gm, works with standard amplifiers and servocontrols, and can be integrated into most bearing structures. Exceptional move and settle characteristics make the motor suitable for operation in vacuum and its small size and weight make it ideal for end-of-arm tooling requirements.
Nanomotion Inc., 1 Comac Loop, Suite 14B2, Ronkonkoma, NY 11779, (800) 821-6266, nanomotion.com
