Polypropylene Syringes
Industrial polypropylene syringes come in three colors and six sizes for dispensing a wide range of light and viscous fluids.
POLYPROPYLENE SYRINGES
The syringes feature zero-draft barrel IDs, drip-free pistons for dispensing light fluids, a 0.092-in.-wide dispensing orifice to assure proper fluid flow, and ANSI/HIMA MD70-1-1983 standard luer lock threads. They are supplied as complete packages (including barrels, pistons, end, and tip caps) or as individual components in sizes range from 1 to 50 cc. They are available in black for visible curing applications, yellow UV block translucent for up to 390 nm, and clear for dispensing epoxies, adhesives, glues, and solder paste.
Fishman Corp., 192 South St. Hopkinton, MA 01748, (800) 433-2115, fishmancorp.com
