AC/DC Junction Box
The M12 eurofast ac/dc junction box contains an integrated dc power supply that allows the use of dc sensors in ac applications.
The four-port box provides 85 to 132-Vac input, 100-mA output per port, and 24-Vdc output to pnp short-circuit protected sensors only. A die-cast aluminum alloy housing provides IP67 protection when all ports are connected or covered with closure caps. A seven-pin minifast connector provides home-run-quick connection.
Turck Inc., 3000 Campus Dr., Plymouth MN, (763) 553-7300, turck.com
